Hi Guys,
Bit of confusion with the set up i've chosen
Decided to go for:
- Denon dm40 with scm40 speakers
- Denon DP300
My questions are - can I buy premade wire, about 1.5m to connect all that? Also, what wire will I need to connect my PC to the hifi so I can use the SCM40 speakers with the PC?
Secondly, Do I just run the wires for the speakers into the hifi, the pc cable into the hifi then run a cable from the dp300 to the hifi?
Its the cables that are causing the confusion
Decided to go for:
- Denon DP300
