I've had a Samsung LE40M8 for a year and deciced to add a amp. I got a Yamaha DSP-AX863SE.
I've connected the two with a QED HDMI cable then connected up my Tannoy 611's Mk1, using the bi-wire option. I'm waiting for the centre speaker to be delivered and will then connect that with my Goodmans Maxim 2's for the centre and surround sound.
So with just the front speakers connected I tried to get it to work..!!!
The amp should on the front display show HDMI connected/recongised. Which it didn't. On the TV I pulled up the HDMI screen and can go through the set up menu with no problems. Once I've finished the set-up the HDMI channel says no signal
And that's it. Any idea on where I'm going wrong will be gratfully received, Thanks for taking the time to read this.
Dave.
Dave.
