Thanks for response Clare. And thanks Margetti for your '2001' DVD/BD, BDP-320/PS3 back-to-back comparisons.
Just to be belt-&-braces, so that all HDMIs from the BDP-320 to the TV are 1.3 spec, I upgraded the AV amp/TV's HDMI from 1.2 to 1.3 (QED New Performance HDMI-P) - no change.
Collected replacement BDP-320 from Richer Sounds on Sat. Opened the box &... it's a 'used' unit - dust on the front panel & packaging missing (the strip of card with Pioneer logo etc) & the top panel has 4 distinct footprints from where another AV unit has sat!!
Decided to give it whirl, anyway. Grrrrrr! Same problems as before: BD playback no better than PS3's; DVD 1080p playback worse. 320 has macro-blocking & 'swirls' in blacks that are not present when same DVDs are played on PS3 at 1080p.
Assume that I've mistakenly been given a 320 that's also been returned with same fault(s) as my original?
Meanwhile, RS has no further BDP-320s in stock...
