Hegel H160 or ATC SIA2-150 paired with ATC SCM19 Mk1
jeetra
Hi All,
Getting dangerously close to pulling the trigger on a new amp. It is down to the last two. I know that the two mentioned are very different propositions, but I would love to know if anyone has A/B tested them, what were their thoughts, and which one they opted for.
In my case, I am only concerned with the respective sound produced by these amps. I have a solid external DAC and streaming solution (all FLAC), so the fact that the Hegel offers these is not important. I listen to a vast array of music, from classical to techno, but with a distinct leaning towards electronic, so bass control is high on my agenda.
Opinions gratefully recieved!
jeetra said:
Hi All,
The only guy on here that has done that is steve750 and he chose the hegel on sound quality.
If its bass control your after its a no brainer
Rick from musicraft also deals atc amps and hegel so maybe he will be around to give his view on the 2 amps also
If you're after bass control, you could also consider the Primare I32, which is Primare's take on the more efficient Class D design. I tend to find Class D amplifiers cleaner and more transparent, with a better grip on speakers, particularly more demanding ones than their Class A/B counterparts.
Historically, I have used Arcam amps. Currently have the a19 and the irDAC. Got the scm19's recently and they need more power. I was thinking of going with a power amp, p35 or p38, but rather than mess around with a bolt on solution, I fancy going for something up the quality scale.
Hi jeetra
Thanks for your reply.
Fair enough however with an irDAC then i feel you should also look at Arcam's A49. As i write this we've got an an A49/irDAC/curved SCM40's playing and the combination sounds stunning
Fwiw, i'll recommend that you also consider Naim's SuperNait 2/Hi-Cap DR and Hegel's H360 which we and some of our clients find to also work well with ATC passive monitors
All the best
Rick @ Musicraft
