headphone amplifier
stiffbuy1
23
hi, does anyone have any suggestions about buying a headphone amplifier my audiolad 6000a amplifier only has a Pre-out RCA left/right to connect to a headphone amplifier, so i am looking for one that will connect to the audiolabs pre-out conncetions, my buget is around £350 ish new or second hand,thank you tony
Deleted member 188533
I owned the HD650 for about 6 years. They respond very well to warmish class A amps. They also reward good tube amps.
Aune X7S
Schiit Asgard 3
xDuoo TA-20
Darkvoice 336
Little Dot MK II or MK III
If you just want a neutral amp with no coloration then there are a bunch of choices now. Any of the newer amps based on the THX amp circuit from Monoprice, Drop ( Massdrop ) or SMSL. Topping makes very competitive amps without the THX module. Geshelli Labs, JDS Labs.
mswan
It depends upon you, How much you want to spend.
In amazon, there is a 4-Channel Portable Stereo Headphone Amplifier - Professional Multi Channel Mini Earphone Splitter Amp w/ 4 ¼” Balanced TRS Headphones Output Jack and 1/4" TRS Audio Input For Sound Mixer - Pyle PHA40 BLACK.
It's cost is $19.00
