Hi All,
After help and advice on mains cables -
I have been researching this for a while and so far the only outcome is me getting a headache
I want / need some upgraded cables for my kit, as in -
Amp, Plasma, Sky HD, BluRay, Sub and HDD (+ HiFi in other room).
I have a dedicated mains supply (32amp spur on 6mm cable) which has a twin (unswitched) socket at the business end.
I intend to replace my (gimmicky) Monster HTS1000 mains conditioner which includes all the considered bad things, namely switch and neon indicators.
Replacement will be 1 or 2 Tacima 6 way conditioner blocks.
Now firstly, do I plug both into the mains socket or run 1 off the other and plug my amp directly into the other mains socket ?
Secondly, without spending an absolute fortune, which cables do you recommend for each device - all the same or different ones for each ?
Any help much appreciated and will help me keep the last of my hair.
Regards Si.
Regards Si.
