HDMI
They're available direct from hdcable
http://www.hdcable.co.uk/products/hd-cables/H1007NT/
I use a couple of the Pro2 (£10) jobs in my own system. Prompt delivery and very helpful folk. Order with confidence.
I've bought a couple of cables from them and always found them very helpful and prompt
I bought a couple of their pro2's, a 1m and a 5m and they seem very good cables. Picture and sound quality is excellent and so is the construction of them too. Well recommended for the price.
Nick
The build quality is great, I'm still to try them out though! ÿBlummin' builders!!
Im interested in these too, what do the whf team have to say about these ones even though they are not a well known brand?
well its getting good reviews and at its price i dont think you can loose, its future proof and well made! And your not paying for the name but only the product which is very tempting. It looks like it will do the job if not better! AND its a 1.3b so for the price and maximum interference shielding wow i think ive sold it to my self BLUSH lol 🙂)
http://www.amazon.co.uk/High-Speed-PLATINUM-Cable-Full-HD-10-2Gbps/dp/B0015YDSWW/ref=sr_1_10?ie=UTF8&s=electronics&qid=1232574011&sr=8-10
Technical Details Highest specification 10.2Gbps future-proof high-speed bandwidth Latest revision version 1.3b specification with Full-HD 1080p resolutions supported (inc 24fps) Full support for 120 Hz frame/refresh rates, 12-Bit Deep Colour, x.v.Colour, Dolby© TrueHD and DTS-HD Highest grade oxygen free copper with individual triple mylar cable screening for the cleanest signal transfer & maximum interference shielding Unique HD Cable patented metal headshell assembly using 24K Gold connectors & protective nylon material cable jacket = superior professional robust build-quality & durablity
Oooh imagine if its better than VDH or the Chord Silver..would be the dream hdmi at 20 quid lol
Andrew Everard:
roger06:The Amazon page says it all doesn't it? 17 reviews - all 5 out of 5 stars...
Yes, incredible...
Would be nice to see you guys review this cable
Andrew Everard:Why? It has 17 five-star reviews already - why do you need another opinion?
I would guess the reason for 'Asking' ............ is so the experts (in this field) who have the resources and experience and who can compare the cables side-by-side should and would be able to supply a more definitive answer (?)
After all, we already know that 'reviews' on sites such as Amazon are often written by the same person, using several different user ID's (if at all needed to post a comment) and very possibly they work for that actual company who either makes or supplies the item being reviewed?
Whilst it is all well and good for your magazine to review Cables from the likes of QED, VdH, Ecosse, Chord, etc ..............etc ............ and rate them all quite highly, not all of us have deep pockets and can afford the high prices these cables command. And in many reviews I have read where cheaper cables are commented on (albeit very briefly), no real explanation as to the differences in quality is really explained.
So how about a 'Credit Crunching' review on some of the cheaper cables such as the one mentioned in this thread, compared with the high flying and more expensive ones I keep reading about in the magazine and on this site?
Don't get me wrong, quite often you do 'Get What You Pay For' ..................... but there is often a cut off point where ''Quality'' does NOT improve, despite the price increasing? ................. (Case in point) ..... How is it QED cables are rated quite highly, but a rival magazine can afford to give away a £75 (supposedly) 1Mtr HDMI cable if you take out a £47 Yearly subscription .............. [I've just received my Cable and will be cancelling my Trial Subscription as their magazine is no where near as good as What Hi-Fi!!!].
So how about it then ............... a test between these 'budget-end' cables and some of the 'mid-range' & 'upper-range' ones ............... ???
_____________________________________
BTW ........... Great website & magazine.
Is it because the big leading brands in cables sponser / support certain magazines that they get there name splashed everywhere where cheaper brands dont because they don't have the power? No pun intended lol.
ScoobyCanDo:
Cynical ................... ? ;-)
But a Good Point?
lol well it happens in other area's 😉
randydevilad:Is it because the big leading brands in cables sponser / support certain magazines that they get there name splashed everywhere where cheaper brands dont because they don't have the power?
Was only a matter of time...
RE: Budget Cables?
So I ended up getting a QED 1 Meter Performance Cable for the grand cost of £3.93 + the cost of a stamp (sending in my subscription cancellation) ................ does this mean MY QED cable will be just as bad as a Tesco Budget Range one .............. costing 4 times as much???
LOL
No.
Andrew Everard:
No.
So can you explain why cheaper brands dont realy get a mention then?
ScoobyCanDo:After all, we already know that 'reviews' on sites such as Amazon are often written by the same person, using several different user ID's (if at all needed to post a comment) and very possibly they work for that actual company who either makes or supplies the item being reviewed?
Golly, do you really think that happens?
ScoobyCanDo:How is it QED cables are rated quite highly, but a rival magazine can afford to give away a £75 (supposedly) 1Mtr HDMI cable if you take out a £47 Yearly subscription
I guess Armour gives that magazine a very good deal on the cables in return for the publicity such an offer creates - it's how it works with our subs offers.
ScoobyCanDo:So how about it then............... a test between these 'budget-end' cables and some of the 'mid-range' & 'upper-range' ones ............... ???
I'll suggest it to the test team.
ScoobyCanDo:BTW ........... Great website & magazine.
Thanks.
randydevilad:So can you explain why cheaper brands dont realy get a mention then?
Probably because those brands choose not to bring their products to our attention, whereas other brands do.
Andrew Everard:
Yeah guess your right actually because those bigger brands can afford too
