HDMI to DVI - any recommendations?
HI all
Finally ordered my Sky box after much procrastination. Got to connect it to my DVI-only Phillips telly.
Am I best off going for a Chord HDMI to HDMI and then buying some kind of adaptor? Or should I go HDMI to DVI?
Does it make any difference?
Any help much appreciated.
Messiah
Personally I would go for the HDMI to HDMI with an adapter. Not because I think there will be much difference in performance but at least you can still use the cable without an adapter if you get a new TV.
