scene:Splash out £5 on a ThatCable HDMI - they're superb, then trial a £50-60 chord next to it - if its 10x better (maybe even 5x better) in your opinion go for it and you've only wasted £5....
To tell if there is any difference in picture, I would need to buy 2 hdmi cables, 1 from the bd player to the av, then one from the av to the tv. but I would only need 1 to see if there is any difference in sound, from bd player to the av. In your experence is there that much difference in the quailty in sound?
Then take the qed cables, you get the entry level and the top of the range level, is there really that much difference in quality to warrant spending that much more money.
I will need 3 hdmi cables all at short lengths
