HD or not HD
Dermondo
132
Hi all, I have a Sharp Aquos 37" P50, an excellent tv on recommendation from What hifi, excels in standard def and with dvd's also to a max resolution of 520p, the question is if I get sky HD with this tv will I notice a difference in quality using 520p or a HD ready tv using for example 720p or can anyone suggest a solution maybe, many thanks in advance to all who reply.
Dermondo:Hi all, I have a Sharp Aquos 37" P50, an excellent tv on recommendation from What hifi, excels in standard def and with dvd's also to a max resolution of 520p, the question is if I get sky HD with this tv will I notice a difference in quality using 520p or a HD ready tv using for example 720p or can anyone suggest a solution maybe, many thanks in advance to all who reply.
If your screen has hdmi connectivity (which I believe it does), then yes.
