Given a Gift Voucher for 20K, what system would you buy?
paulkebab said:
£8k on DSP hardware and an engineer to set it up, feeding a 500 WPC Nord amp setup. The rest will go on their nominated builders to sort an anechoic listening room as an extension to my existing room... and furniture. Phewwww it took me ages to think of that!
That's certainly one of the most interesting answers in this thread. *drinks*
I don't think so, having been in an anechoic chamber on a couple of occasions I can assure you that it is not what you want as a listening room.
Treating a room to sound great with full (ish) range speakers isn't difficult, you just have to be prepared to lose a lot of space to bass traps and put up with some pretty wierd looking treatment panels. Not cheap but not £20k either.
The biggest problem is sound insulation, if you have any neighbours and want to play at reasonable levels, this is the real challenge. Truly effective solutions usually involve a 'room within a room' approach, the listening room is built on a floating floor and not structurally connected to the main room, a big job for which the £20k budget will be nowhere near enough.
about the level of you music, use the voucher to buy six of these:
problem solved, no more neighbours, possibly no more house either. *biggrin*
They don't come much weirder than mine. *biggrin*
If you are wondering why the chair is covered it's to reduce reflections from the chair.
All of this acoustic treatment is work in progress but the effects so far are nothing short of astonishing and it will be made to look more professional sometime in future, ---- maybe .*biggrin*
Definitely not £20k's worth of treatement but it does make £20k's of improvement to what was a very good sound before. imo *smile*
I just worked out my current system including TV costs £13k, so I would probably buy the same system again, but I think this thread is Hifi anyway, but a home cinema system can be two things. Especially with my Arcam rBlink.
