Getting a new CD player
Greenwich_Man
106
32
18,620
I have an old Marantz CD player that now skips on some CDs. It's a Marantz CD 6003. Someone is recomending I replace it with a Sony DVD player.
What are your thoughts please?
Quite a few people go for DVD players when their CDPs pack up.
They're a cheap option with the option of using an external DAC.
(If not quite as operationally convenient as a dedicated CDP)
Maybe you've already opened up your 6003 and had a look - to ensure a spotless laser lens and no dried out lubrication on moving parts - that's what I'd be doing first.
Someone is right in that any DVD player can play CDs, but I’d not be optimistic about the sound quality, unless you’re feeding the digital output into a decent DAC.
The Marantz could be serviced, or if the estimate is too much, then I’d suggest you put the money towards a new 6006 model, or a used 6005/4.
it Could be something simple, like the lens needs cleaning, or the mechanism is sticking. ( had a rega do this)
As suggested, pop it open and do a bit of basic cleaning.
If the laser/mechanism is faulty. Maybe a competent computer repair guy could pop one in there for you.
Or, use it as a reason to upgrade? If you go for the 6006 uk se, it has a front USB port, so you can use that instead of the cd drawer.
I do this now with my SA14S1SE. 👍
I was going to replace my old defunct CD with a CD6006. The CD5005 seemed to compare favourably and was much cheaper. I don't need a USB port. I got a mint condition one from an Az warehouse deal on Prime Day for £134, which I consider a bargain. .
I'd agree that it is worth trying to clean the lens first.
I think all 3 unit's might use the same dac (CD5005,6006 and PM6005), so buy what ever is cheapest and use the built in dac in the PM6005/6006 will give you CD6006 sound quality or very close if you don't use a marantz cdplayer.
If Greenwich_Man has a PM6005 or 6006 amp he could use the dac with a cheap cdplayer if cleaning the lens don't work
Thanks so very much. You have given me much to think about. I have cleaned the lens and a brand new CD isn't working well. Thanks to all of you for your contribution.
Take it to a doctor, mabye it's just a new laser which isn't expensive
Reactions: Greenwich_Man
What did you do with your old CD player? I might be interested in it.
I have replaced the laser in a CD63 MK II and it works now but only if you buy genuine Phillips lasers , some of those on ebay are worse than the ones you are replacing.
Hi Greenwich Man,
I got a notification by email but your post is not here.
I'm also on Artof Sound forum, have you looked there? They allow PMs.
I'll send you a PM.
Majex45
