Weakness in vintage setup
Badgeraudio
I recently used FB Marketplace to get a few used separate bargains to go with my dad’s old Goldring Lenco 75 which I had recently refurbished. I bought a Marantz CD 52 Mk2 CD player, a NAD 302 (not 3020) and some Mission 780 se speakers and even though it’s only a smallish room, I find the sound a bit lightweight for my taste. Definitely lacking in bass from both sources. I do prefer a warmer sound. ChatGPT says replacing the speakers would make the biggest difference but I wanted to get real people’s opinions on where to upgrade first for something a bit warmer and bassy but still retaining detail. Any ideas on what I should replace and what to get? The room constrains me from using floorstanding speakers. Thanks.
Question: if you cannot use floorstanding where and on what are your current speakers placed?
Currently on top of a wide TV cabinet.
Not ideal but I know the speakers you have are front ported. Perhaps something rear ported may help as would playing with repositioning.
I might suggest some Wharfedale Diamond 11.1 speakers, it very much depends on your budget.
Is the lack of bass the same with both CD and your turntable?
Which cartridge do you have on the turntable?
Oh, and welcome to the forum by the way.......
Of course ChatGPT would say that changing the speakers would make the biggest difference, because it's just mining what everyone else says on the internet. It doesn't take into account system/room/placement/budget variables, just like the people who state this blinkered viewpoint.
Reactions: GroeneLeeuw
Great to try swapping things around but the 780SE isn't the bassiest and while it'll likely have Mission's trait of excellent detail and imaging, if you just want more thump - and can't tweak speaker positioning much, which you should try before anything else if you can - then this would be the thing to go.
Much as ChatGPT landed on the right answer here, it's not always so great so I'd caution against relying on it for too much of the time. And to be honest, it's probably a good thing for you to be able to do your own legwork on some of this stuff.
Reactions: Badgeraudio
The biggest change after the room is the speakers, which is why they should be the first thing to change when upgrading, it also has the advantage that they will show up any problems with the rest of the equipment, making it easy to chose what to upgrade next.
Bill
You may be hearing resonance from the cabinet, but please check this:- are the speakers in phase?
That means positive terminal to positive from amp to speaker, in both channels. And obviously negative to negative. If you’ve accidentally reversed one channel you’ll have no bass, because one speaker blows when the other sucks, if you get my drift?
That means positive terminal to positive from amp to speaker, in both channels. And obviously negative to negative. If you’ve accidentally revered one channel you’ll have no bass, because one speaker blows when the other sucks, if you get my drift?
Thanks I will check but pretty sure I did. The speakers are biwirable and the bit of metal between the 2 sets of terminals are very fiddly though and took a while to wire them
The speakers are small, especially compared to the 701 from a few years before, but don't tend to sound small. I would start by double checking they are in phase and the left and right speakers are the right way around.
Secondly look at position. They are front ported, buy bass still extends all around. How far are they from front and side walls?
How big is the room. Is it closed off, or open plan? Where do you listen from in relation to the speaker’s?
Many room,spaker comboes lack bas because of the room
Thats why room correction makes a big difference in the bass
Lack of bass due to room is poor speaker placement. Low frequencies cancelling each other out. Fix this by moving speakers before resorting to room correction.
Most systems sound pretty good if the speakers are correctly positioned.
Reactions: record_spot
Room correction is great once you have done everything else. It's a final polish, not a fixall!
It isn't magic. If you try to use digital correction to boost a frequency in a deep null, the cancellation just gets deeper, pulling more amplifier power.
Though I think room set up is important, there is clearly something lacking for me that that alone would not account for. Plus my room set up is not very flexible as it’s also my office. I think I need maybe a more powerful amp and some speakers more capable of lower frequencies. Any suggestions for those would be good for the 200 quid used mark for each.
General advice is to change one component at a time. If it's bass you are looking for, the speakers are where to start, they only go down to 70Hz, many standmount speakers will go below 50Hz.
Are tou looking at standmount/bookshelf speakers, or do you have room for floorstanders?
If you are looking for standmount at that price Tannoy M2 are outstanding. They tend to sell for £90 to £150 but don't come up often. Mission 701 would also be a good buy for around £100.
You had plenty of headroom, with double the power of the OP, I wonder why that is? 🤔
I turned it all the way up in the bass and loudness it played super loud bass and speakers didn't get damaged Philips 22 ah 305 + sealed speakers
A nad 3020 also have more power than most big amps form that area, has nothing to do with continous power
A diesel engin with 100 horse power can also have more power than a 120-130 hp petrol enigne (the old 1.9 tdi vw engine had alot more grunt than on paper bigger enignes with more horse power)
