Hi all!
I'm in the process of looking to change up my current system, moving away from a valve amp to something a bit simpler.
My current setup is as follows, and has been for about the past 7 years or so:
Amp: Rogue Audio Cronus Magnum
Speakers: Tannoy Mercury M4
Record Player: Audio Technical AT-LP1240-USB
The primary aim for the new build is to:
1. Change amp to something less heavy (this thing is a beast at ~25kg and I am worried it will no longer fit on our shelf)
2. Upgrade speakers and record player to something more in line with the amp in terms of quality
3. Speakers ideally need to be bookshelf and sit on a 30cm deep shelf).
I have also attached a pic of the shelf for reference that everything will be sitting on.
As a side note, does anyone have any idea what the original Rogue Audio Cronus Magnum would go for these days?
Any help would be greatly appreciated.
Thanks and take care!
