Ajani:manicm:Ajani:manicm:
Ajani:I do find the decision not to include digital outputs to be silly (as digital outputs would make the product upgradeable)... However, I suppose the logic is that they want to give you an incentive to buy the more expensive version, when you're ready to upgrade instead of buying a DAC..
The O4HD ($2300) is more than twice the price of the new O3HD ($1000). I would not call that an upgrade.
Olive is simply offering a cheaper entry point for customers. The only thing that would concern me is the sound quality as they use a cheaper but equally capable DAC i.e. will still play full-fat 24bit/192khz files.
Their thinking is that, assuming sound quality is acceptable, customers like myself would not bother with the networking abilities, additional capacity (500GB would be enough for some), or the need to connect digitally out or in. (After all Linn's top 3 DS players do not have any digital connectivity.)
If I could be assured of the sound I'll be saving now for Christmas 🙂
I guess we disagree on what an upgrade is... For me an upgrade is going to be at least double the cost of the item I own, as anything else would be a very minor improvement...
Also, while I think this version of the Olive maybe just what many persons need, if the sound quality is not what you'd like, then you have no easy option to improve the performance... You just have to sell it and buy something else.. So that will scare some persons off... keep in mind that so many HiFi types love to upgrade their systems...
Linn is a different example, since you are talking about their top 3 players... a top of the line CD Player or Music Server doesn't need a digital output, since the logic is that it is the best of the best (hence nothing for you to upgrade to)... Budget models on the other hand, are expected to be inferior to higher end models and so people often will upgrade them...
If Olive had Digital outputs on the 3HD, but not on the 4HD that would make more sense since the 4HD is their top of the line product... But not including it on the 3HD may hurt sales of that product...
If it doesn't sound right I won't buy it at all - your comment doesn't make sense.
Let me add some words to clarify the point:
Assuming it sounds fine when you buy it, but later on as you upgrade amp and speakers you find it to be the weak link in the chain.. then guess what? you can't just upgrade the Olive by adding a DAC. you need to buy a new music server...
If a decent source does not sound good in the first place, a better amp or speakers will only magnify its weaknesses.
On the the other hand if you are happy with a source, then better speakers and amplification should enhance its strengths, not hamper it.
On the Olive specifically - you can read the HFC (? or the other major UK mag) review online at TechRadar. Yes they considerably improved the O4HD's sound with an external DAC - the 2000quid Naim DAC. Good luck to you if you have the cash.
I stand by what I said - if it doesn't sound good to me I won't buy it, simple as that. A good source is a good source. And a bad one bad.
