insider9
No, to most extent.lpv said:regarding mic and measuring equipment would the below comment by Alan Shaw be of any concern?
http://www.harbeth.co.uk/usergroup/forum/the-science-of-audio/getting-the-best-sound-in-your-room-using-damping-materials/113-testing-room-speaker-acoustics
Here's why. Umik-1 is USB a calibrated mic. Most will output the signal to an external DAC which even if it's not completely flat will process sweeps exactly the same as music hence will react in a same way.
I've started with Behringer ECM 8000 and was far from pleased with the process.
In the 9 months I've taken thousands of measurements of many different speakers, amps and dacs. I can safely say that results are not only reliable and repeatable but also accurate.
