Deleted member 188516
i believe it is common knowledge that by reducing a speaker cables resistance only positives can result. (such as an amplifier being able to better control the speakers it is driving).
as a result, the advice to use the thickest (multi strand for flexibility) speaker cable possible usually means 500 strand is recommended although, i believe, higher strand numbers are available.
the limiting factor though is how many actual conductors can be attached the the banana plug or spade connection being used.
a way round this would be to use 2 runs of the same cable but one with a spade connection and another with banana plugs. this should then allow a doubling of the speaker cable used but a halving (correct ?) of the cables resistance which should result in an increase in performance.
agree ?
agree ?
