ellisdj said:
Where there is a will there is a way - can get things much better - more cinematic if that is what you are after.
One thing I do really good is sound, and its the sound that makes everything you watch what it is - its the sound that captures the emotion not the visuals. Its more important.
I didnt even get started on your bass
Also agree.
@ Gel
Less expensive (appropriate) equipment, correctly installed and set up, will sound markedly better than expensive equipment that has been "thrown in", with little thought/expertise.
- Try moving your room about, as Ellis has suggested
- If going ahead with an upgrade, spend some of the saving (by not going mad), on
(i) A day trip out to a good dealer, who has the equipment you want to hear...bring photos/room measurements.
(ii) A proffessionally done installation
This will be the best money you will have spent in some time....and is worth every penny.
FWIW. I would still be looking at the AVR850. I have first hand knowledge of just what a difference this level of upgrade can make. I previously had the AVR350, which was a highly regarded 1500GBP receiver, in its day....the difference the AVR600 made was remarkable. It sounded like I had also upgraded the speakers as well (Kef IQ9).
I am trying to structure this reply in such a way that I am not encouraging you to spend needlessly or inappropriately.....but carefully, methodically and appropriately.
I'm aware you have funds to throw at this and wish to get you into something that will bring longterm pleasure, for your 40th....which is why you need to carefully consider the excellent advice you have been given so far....as this adventure has the potential to turn into a very expensive disaster.
Maximize the room, get good advice, buy sensibly (based on dems) and get it properly installed....and you should have years of pleasure.
