Does altitude affect hifi performance?
drummerman
540
I've lived for a few years on the second floor of a conversion and recently moved to a first floor one.
Can I expect better performance as I'm closer to sea level now?
Vladimir
220
7
I believe you will now experience a more flat frequency response. However, I personally enjoy music more at high altitudes. For this I use hemp rum.
tonky
36
I liked listening to music when I was high - even the carpet seemed to move too.
Everything seemed to have more depth - toe tapping etc -
Tonky
chebby
1,253
26
19,220
If you had great views and lots of light on the 2nd floor, then no views / no sunlight on the 1st floor then your mood will change and your enjoyment of music could be affected.
pauln
137
As sound travels more slowly as altitude increases (various scientific reasons so clearly of no relevance here really) you may find that since you moved to a lower altitude the sound is reaching your ears more quickly and you perceive more PR&T. Certainly the pace will have increased, don't know about the rest of it.
Anderson
drummerman said:
Thank you helpful forum experts.
I will try and take it all in ...
If you do decide to inhale make sure you have nothing to do for a few hours, don't want to ruin the mood worrying about something. Go in with a clear head and then you'll have plenty of fun.
emperor's new clothes
35
I've listened to HiFi at 5,500 feet asl and headphones at upto 47,000ft and would suggest the answer is no discernable difference.
Vladimir
220
7
plastic penguin said:
If you was to spread butter over the top of a Cyrus amp and lob it out of a two-storey window, wonder which side it would land? Just a thought.
Supereverard will fly in and save it!
steve_1979
231
10
18,795
At 47,000ft I assume you were in a pressurised airplane cabin. ;)
Serious question though.
With an increase in altitude you get a reduction in air pressure. Can someone explain (or provide a link explaining) how changes in air pressure effect sound waves passing through it?
Freddy58
126
103
18,770
I don't know, but I DO know that in space, no-one can hear you scream *sad*
Vladimir
220
7
With an increase in altitude you get a reduction in air pressure. Can someone explain (or provide a link explaining) how changes in air pressure effect sound waves passing through space*?
*considering sound is air vibrating in the form of waves.
EDIT: Freddy beat me to it.
tonky
36
listening at the top of mount everest. As the air pressure is reduced at the top of said mountain the speed of sound is reduced. I don't think you would notice much (if any difference sound quality wise.The speed of sound is different for different frequencies ( another kettle of worms) Assuming you listen in a heated tent - the temp will effect the speed also. And you'll never be able to brew a cup of tea either!
tonky
steve_1979
231
10
18,795
We had a quiz at work the other day and one of the questions was "At what temperature does water boil?" to which I lost a point for answering "The boiling point of water is pressure dependant."
Stupid f***ing quiz book doesn't know what it's on about!
100°C my ar**! *dash1*
35
From distant memory, the speed of sound varies with temperature and very slightly with humidity. It is not affected by pressure. It is proportional to the square root of ambient absolute temp (deg K). Temperature decreases at 1.98deg C/1000ft upto the tropopause. Survival at 47000 is about a minute before black out due hypoxia. Aircraft cabin pressuried to @8500 feet. Tis the season for trivia
