Digitial coax out on Panasonic DMR-EZ27 ??
I'm looking to buy the above dvd recorder. Magazine says it does have digital coax out which I need as only other input on my amp is optical which I'm using with Sky HD, but lots of websites say it only has optical out. Does anyone know the correct answer ?? Also, any ideas where I could buy a multi-region player ? Easy to find a standard one but multi-region not so easy. Thanks for your help.
[quote user="Spike66"]I'm looking to buy the above dvd recorder. Magazine says it does have digital coax out which I need as only other input on my amp is optical which I'm using with Sky HD, but lots of websites say it only has optical out.
Thanks for your help.[/quote] Definitely no coaxial mate - if in doubt use avland to find out about spec! http://www.avland.co.uk/panasonic/dmrez27/dmrez27.htm
cheers mate. Might have to look at something else then as I only have one optical in on my amp.
