Hi after waiting for many months for the sales to start, i saw the Richer Sounds sales start and thought this would be a good stepping stone to getting my ideaL home cinema system.
So i went ahead and bought a Denon AVR 1910, im also looking to buy a Mission MCube 5.1 speakers but need to save up more for that well i asked the guy at Richer Sounds if its possible use the unit to connect all my equipment to improve the quality until i buy the surround sound and he said this is possible you can just use the TV's own speakers for the time being, he just recomended i buy Scart to RCD (not sure the name scart which has 6 plugs at the end) to use for all my equipment that has scart output. It all sounded luvly until i got home and spend around 5 hours trying to get it to work, the only thing that worked was the PS3 which is on a HDMI cable.
what ive done up to now - i only saw two outputs for the componets one that says DVD the other DVR
- for the Virgin box i connected Green Blue and Red from the RCD to the Component Part of the AVR Unit saying DVD
- for the Satelite i connected Green, Blue, and Red from the RCD to the Component Part of the AVR Unit saying DVR
- The PS3 HDMI cable i connected this to HDMI Output but im still not sure which output to connect this to as on the side it says DVD, HDP, SAT,DVR
can sumone please help me know how this should be connected please and what seetings i needs to do to get it working
