professorhat:Ah yes sorry, it's not particularly clear on the website but I now see it upscales to 1080i.
You had me worried for a minute there prof. It does 1080p.
DENON AVR2808
Available in Black & Silver
Video conversion to HDMI v1.3a and 1080p upscaling
High quality I/P conversion for HDMI
Dolby TrueHD and DTS-HD decoding
DDSC-Digital featuring Analogue Devices HammerHead SHARC 32 bit floating point DSP processor
Audyssey MultEQ XT Auto-Setup and Room EQ function with microphone supplied
7 Channels equal power amplifier section
110 watts per channel (8 ohms, 20 Hz-20 kHz,
ALPHA 24 Processing (AL24) on all channels
Adjustable High and Low Pass Crossover (40/60/80/100/120/150/200/250Hz)
12bit/216MHz Video DAC
"Compressed Audio Restorer" for higher quality playback of MP3/AAC via the optional iPod dock
Assignable Component Video inputs (100MHz Bandwidth), with On-Screen Display
7.1 external wide bandwidth (100 kHz) inputs for multi-channel formats, such as DVD-Audio and Super Audio CD
Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +18dB
Audio Delay adjustment to match audio signals with video signals (0-200ms)
Built-in RDS AM/FM tuner with 56 presets
2 Multizone functionality with Discrete Power, Source Select and Volume control for each zone
Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive Zone 2 speakers directly
2 12V Trigger
IR in/out terminals
Learning remote
Optional ASD-1R iPod dock available
Full System Setup/Parameter control on front panel, with feedback on front panel display (Monitor is not needed for setup)
