Given the debate raging in another thread about a certain active speaker range I wanted to understand the difference between an active and a passive speaker set.
I know that the RA-04 and set of BR2s I've got are a passive set of speakers, that bit is easy.
I understand that an active speaker has essentially got a power amp attached or integral to the design. The ADM 9.1s see to have it integrated, whereas the ATC range of actives have a power amp attached to the back. I understand you need a pre amp or a DAC to feed both types?
What else makes these active speaker designs, the cross over design? Can you suggest some other examples?
Not actively looking to go and buy a set, more curious about the difference
thanks
thanks
