I've recently bought the AKG550 headphones for PC use, and I'm very satisfied with them (seem to have improved a lot, even), but unfortunately, there's constant, pretty loud static throughout, which actually gets worse when there's movement on screen (anything from moving mouse cursor to video). It occurs both when they're plugged into front and back jacks. I'm not much of a techie, but supposedly this is because I have an onboard soundcard (Realtek ALC1200) and, because of lack of shielding, there's interference.
Now my solution is to buy a dedicated sound card. Unfortunately, the AKG550 has an impedance of 32 ohms, and the Xonar soundcards I'm looking at (DGX and STX) have an output impedance of about 10 ohms, which would result in some sound distortion. Is that correct?
Would buying a dedicated sound solve the problem of static? Would the impedance mismatch actually audibly affect sound quality, or would there still be a good improvement in audio quality? Would it be better to stick with my current onboard audio, and look for another solution, not requiring buying a soundcard?
Thanks for your help.
