Hi all, I have just purchased some dali Oberon 5s, great sounding but at times feel too bright. Was wondering if the sensor 7s would be a slightly warmer speaker? Will be pairing them with the rega elec r. Would appreciate any suggestions. Cheers.
Speakers are different when it comes to grilles on or off but generally, in my experience grilles only make a subtle difference.Cheers for that, will give a go, would putting the grills on also help with the treble?
That might be the case with a Brio, but the Elex should have better clarity and should eliminate the muffled sound. The only way to know is to demo some Qs with your amp. If you buy without hearing you could spend a lifetime without finding the ideal compromise.Hi thanks for the advice, is worth thinking about. The reason I bought the Dali’s is because I used to own the q acoustics 3050i but paired with a brio, thought the sound was slightly muffled , so decided to go for some slightly more brighter speakers, it may of been a mistake as I imagine the 3050i’s would sound much better with the elex r which I upgraded to.
The Wharfedales could work a treat with the Rega. But FFS get a home demo. If you buy them unheard and you don't like them it'll drive you bonkers.Just another thought, has anyone had any experience matching the elex r with the wharfedale Linton heritage 85 speakers? Really love the look of them and heard good reviews.
personally I don't think a cable change would make the overall sound that much different, if you must try some cheap copper 79 strand cable first.Hi , yes I do. The cartridge I’m using is the at vm95sh, was wondering whether to upgrade my speaker cables, i am using qed xt25 , which apparently can produce a bright sound, was thinking of getting the chord company c screen as being reviewed as giving a warmer tone. Any comments on this?
Agree with Al Ears cables aren't going to solve your issues. IMHO cables are for anyone to upgrade after you are satisfied with the overall sound.Lol cheers for that, will try, although live quite remote and don’t think the nearest richer sounds have them in stock. Your thoughts on speaker cables?
