BrightSpark:
Chief,
You've asked which of the two DACs will work better in your system without saying just how you would use it. You list an Arcam CD and also mention ripped files. So do you expect to use the DAC both as an upgrade to your CDP and for PC based audio?
Honestly, I think you can only tell which is best if you listen to both in your own system.
For what it's worth, I went for the TC-7520. I needed a decent headphone stage, I had doubts about the CA's use of upsampling and the TC-7520 offers the extra possibility of acting as a preamp. Using the TC-7520 as a preamp and connecting via USB you can by pass any software volume control or mixing (well in Linux anyway) and have finger tip control at the DAC itself. Just feed the preamp DAC output into the tape input of an integrated amp. No need for an amp with a remote volume control, and if you want you could use a power amp. I wonder what a Quad power amp sounds like if feed by a TC-7520?
Cheers for the info.
I intend to use it for my Laptop, which i have ripped all my Cd's to. It is not intended to replace my CD player, but i thought i could also try using the Arcam as a transport only just to see if this sounded better than my CD73 on it's own. If it sounds better then great, but if not i can just use it for my WMA files. Some people have said previously that it/they will sound better than my Arcam outright, and others have said that there will probably not be much, if any sound benefit from using the Arcam as a transport. The way i see it, is that i have nothing to lose as i don't intend on selling/replacing my CD player outright, with a DAC. I still like playing CD's too, just not all the time.
