DAC Dragonfly Red with Windows
burgundio
I like very much the Dragonfly sound and I have two black units that I've been using at home and on the road for lecturing. I bought a Red in order to try the improvements, but in a few days after a windows update it stopped working correctly - disappears from the system, hangs up the computer, and the like. Is anybody experiencing same problems, and is there a way out? Thanks for any help
Francesco Martinelli - Pisa, Italy
ThisIsJimmy
101
42
120
Hello Francesco
This wouldn't be the first time that Windows Updates create carnage.
Are you able to obtain a list of the updates (KB references) that were installed last, so we can narrow down any potential update that you need to uninstall / rollback?
If you go to 'control panel' and 'windows update', you should be able to identify these from the update history.
Jimmy
Friesiansam
325
204
11,270
I would also suggest you go to the motherboard manufacturer's website and find, download and install the latest chipset and USB drivers. If you are using a laptop, go to the laptop manufacturer's website.
burgundio
thank you very much for all indications. My Zenbook has been checked through MyAsus and is up to the latest updates; but thanks to your suggestions I went to Windows update and I found yet another update that was not automatically installed, and now things SEEM to be back to normal....
ASK THE COMMUNITY
