CRT TV stands
Does anyone have any recommendations for TV stands that will hold a CRT? I am not ready to upgrade to something lighter and I have just upgraded my amp to an Onkyo 606 which has left me very short on space and I have noticed that it has such a large magnet in it that it is discolouring my screen slightly.
Clearly I need a larger stand to get my amp away from my TV. I only have about 95cm width to play with. Any suggestions? Extensive googling has left me with nothing.
Might be best to split the two? So have one stand with your TV on and another stand a few feet away that can have all your other boxes on it (maybe a dedicated hi-fi stand). If you're using your Onkyo to handle all signals, this means your DVD/ BD / any other player you have can all plug into the Onkyo and then a single HDMI runs between this and your TV.
Just an idea.
I don't have the space. I have about 95cm width and something like 60 or 70 cm depth to play with. Basically the space under an old 32" 16:9 CRT.
