Hello. I know its possible to control the squeezebox with the NAD sr5 remote but i don't like the remote - find it too cumbersome / annoying. And I know that you can control the amps vol controls and on off with an IR blaster thingy that emits IR light, but is it possible to connect the 3.5mm jack type IR out on the squuezebox to the IR in on the NAD amp with a simple cable ie direct link so as to be able to control the vol and on/off on the amp with the squeezebox remote - for that is all i want to do!!??
