- Sep 22, 2011
- 27
- 0
- 0
Is there any difference in SQ for the type of connection used?
Is banana plug is better than bare wire or vice verse?
Only for practicality.audipheonix said:Is banana plug is better than bare wire or vice verse?
Paul Hobbs said:Have a look at the gold plate nakamichi ones on eBay, v cheap and sounds transparent. Take a look in the thread in my sig if you want a look at them.
audipheonix said:Is there any difference in SQ for the type of connection used?
Surely if they sound transparent they don't have a sound so they can't sound anything?Paul Hobbs said:Have a look at the gold plate nakamichi ones on eBay, v cheap and sounds transparent. Take a look in the thread in my sig if you want a look at them.
altruistic.lemon said:Surely if they sound transparent they don't have a sound so they can't sound anything?Paul Hobbs said:Have a look at the gold plate nakamichi ones on eBay, v cheap and sounds transparent. Take a look in the thread in my sig if you want a look at them.
Hotspur said:Surely a soldered banana plug is permanently connected, whereas bare wire will sooner or later become loose and possibly short out, or degrade the sound by not having a firm connection.....
Common sense ?
TH
