- Aug 10, 2019
- 2,556
- 5
- 0
ive just spent the last two days listening to the marantz pm7200 amp,firstly in class a(25w) and then class ab(up to 95w).i kept the volume dial at the same setting(9 oclock if you imagine the volume dial as a clock face) and concentrated on 5 different pieces of music playing each a lot of times in the two different modes.the conclusion that ive come to is that in class a the music sounds a lot flater while in class ab the music sounds thicker and richer,almost as if someone has just switched on a loundness button only there isnt one.also what is the point in listening to this amp in class a when youre condensing the music down into a 25w soundworld when this amp has the 95w capacity? im not saying play your music at 95w because its more than loud enough at the setting ive used,but surely if somebody was continually using it in the class a mode it would have been better for them in the first place to have bought an amp with a 25-30w capacity rather than one with a 95w capacity?surely you must be losing something by restricting it.its rather like doing 30 in a ferrari when you could be doing 90.your thoughts please...
