Chord Silver Cable
tj27
30
Hi Everyone
Just ordered some Chord Carnival Silver Screen speaker cable. I've only ordered 1 length @ 1.5m to try on my centre speaker.
I've also ordered it to be terminated both ends, banana for amp & spades for the speaker end (wall mounted) & did not want to bend the wire round too much by having banana ends for the speaker
Hope there is a positive difference to my old Gale wire with Gale bananas & bare wire into the speaker
If it is good, i will order a pair for my BR2 fronts, not have them bi-wired & then use some cut offs for home made jumpers to save on the bi-wire running along the floor/under carpet nighmare im currently having!
Hi mate,
I have used Chord Carnival Silver Screen for my surround sound system in my AV room (also kids play room!!) and it is great.
My kit is a Yamaha RX -V765 and Kef 2005.3 speakers, linked to a Pioneer PDP LX5090 (awesome screen) and a BDP-51FD.
Hi there
With the carnival cable, i could actually here a 'fuller' more pure sound - strange i know but the speaker does have more 'life' to it now.
Couple of days later I have installed a Tacima 6-way mains conditioner (the amazon deal @ £23) which has helped the hole soundstage aswell with my amp, the speakers all around have improved now aswell, more fluent & 'open' sounding, im very impressed with such a cheap upgrade.
At the same time I shortened the Tacima 2m to 1m lead & installed a MK toughplug silver plated with a silver plated 13a fuse, bought 1m of Supra LoRad 1.5mm 3 core mains & changed my ps3 cable - again MK silver coated plug & silver coated C7 plug (fig 8 ) & got some high content silver weld for the fig 8 plug joints. All working perfect & with great success.
I will be ordering 2m of the supra lorad 1.5mm cable to change the panny plasma lead. I already have a silver coated IEC plug & another MK toughplug silver coated & some 5 amp silver coated fuses ready.
Highly recommend the Supra LoRad cable has a very high shielding. & as for the Carnival wire, again a huge thumbs up & a worthy upgrade.
let me know how much you want for the 2no. 2.7 metre carnival leads i could be intrested for my MA BR2's
that is what I found too, much richer fuller sound.
Also bought a Tacima 6 way from Amazon, but bought it mainly for the surge protection as when I had the room done I had a direct AV feed from the main board to cut down on interference and also had switch-less sockets installed, so my electric is pretty clean! Sounds like you have done a pretty good job of cleaning your feed up locally though!
Hi Mate
Thanks for the offer - will speak via email - i did not know trading was not allowed
apologies
Hi mate
They are terminated with banana plugs.
Have sent you an email.
nope obviously didn't know....
Just trying to help someone out.
thanks for letting me know, I'll set aside some time to read through those when I don't have a life anymore
