Cartridge for Rega RP6
Think the Elys 2 would be a good choice, as no need to buy a spacer to raise the arm, but so would the AT95E with the spacer and money left for LPs
Can't help thinking the RP6 needs a cartrdige >£200
+1 that turntable deserves the best cartridge you can afford. If that is your budget then the Elys is best option.
Personally I'd try and save a bit more for a Nagaoka MP-150.
What kind of music do you listen to and how do you like the presentation to be?
The Elys2 is a little laid back for my liking.
I went for a P6 and Elys2 as I wanted to have a direct comparison between my old Manticore Mantra and the P6. Happy to say that the P6 surprised me with its improved bass and mid-range clarity. Still have the P6/Elys2 and yes some will think that the Elys2 is a little laid back, but others will see it as refined and better across a broader range, which I do. I have used the Ortofon 2M Blue too, which is better for rock and a more up-front presentation.
Hello, i have the RP3 which had the Elys 2, no, had a 2m red knocking about, better, then i took a chance on a Shure M97ex.
Miles better, trust me, for the money it's an absolute steal, an Exact 2 with it's vital line stylus may be better but the Shure has nude profile which really digs into the grove and it just keeps getting better the more it breaks in.
