groberton:
Very clever Andrew.
One tries one's little best.
groberton:
So, it may mean that I now have to get a little 'dish-alignment-pointy-thingy' to make sure.
Bah, humbug.
Yes, I think that would be sensible, but with signal strength that low a bigger dish would probably help, too.
groberton:So
is the cause of high pitched clicks and some picture blocking/noise the
dish being mis-aligned or can this happen on the weaker channels even
if the dish is Ok? In other words, because I am experiencing this
intemittently is the dish the only possible culprit or could it be that
my 8 year old Sky box may be on the way out.
Could be any of the above - recently had big probs with our Sky HD installation at home and as well as changing the box, the Sky engineer also changed the dish, which had been up for about six years. Being out in the elements they do deteriorate over time, after all, and since yours has presumably been up for eight it might be time to think about a new one. A bigger one, preferably, if you live in an area with weak signal.
Of course, channels with weaker signal will emphasise any of these problems, too...
