- Jan 25, 2010
- 132
- 0
- 0
Hi all,
When i just had freeview i used a QED Qunex TTV cable to reduce RFI noise to my tv from the outdoor aerial. Now that i have moved onto Sky HD i still get noise of varying degrees from the Sky signal. The amount of noise varies, occasionally all is great and razor sharp other times edges can become quite noisy. Using a direct feed from Satellite to HD box, with Chord Active HDMI, and Tacima Mains Conditioner. Don't get any noise issues with BD, games etc. from direct sources.
Any ideas to eliminate the noise?
QED don't appear to make an alternative cable to the TTV anymore.
Is there a way to filter out the noise?
Worth mentioning that the signal settings on the box are full for signal, and 90% full for quality. So the system data appears to match what is happening on screen.
Please help.
Kind Regards,
Cookie Monster
Please help.
Kind Regards,
Cookie Monster
