emcc_3:I think if the ipod dock is of a high quality it would make mind up with regards which amp I would be choosing between this the RA04se and the Marantz pm6003. Having a built in dock is an amazing feature cant understand why more amps do not have this feature
Hi emcc_3
Yes, i also feel the iPod on the A-S500 is an excellent feature.
Btw, the A-S500 also uses a dedicated power supply for the CD and dock port. They use a One Point Balanced Circuit for the iPod. Current from an iPod is very noisy so this circuit helps reduce noise which allows greater and cleaner current to other circuits, which results in superior performance.
All the best
Rick @ Musicraft
