bigboss said:What do you think about this one:
http://store.aclasstechnology.com/media-server-2566-p.asp
It seems to have everything I need at a good price. I'm pretty sure this won't be fanless though.
bigboss said:Thanks. I'm unable to get info of movies I already have in my NAS. In Boxee box, it's displayed as a movie wall with posters, and when you click on a particular movie, it brings up movie information and names of actors etc. In Kodi, even when I choose to view thumbnails instead of list, it only shows empty boxes with names of files. Any suggestions?daveh75 said:bigboss said:Thanks! Yes, I've been looking at NVidia Shield. Will I get all movie info on Kodi?
Yep.
If you've got an AFTV you really should just install Kodi on it and give it a try.
Thanks, that's helpful. I had a play with Kodi on Fire TV. I like the interface. NVidia Shield is what I'll mostly go for.Feral said:Just caught up with this thread and thought i'd share my thoughts on the Shield TV. I picked one up recently as i wanted to get a more stable experience.
The main plus for me is that the images are much brighter and sharper in my experience over the Pi KODI. The shield itself is lightning fast and as i didn't bother with the 500gb drive version is silent and without the issues widely reported with the pro versions.
The is plays all the latest formats including VC9/HEVC/H.265 and will also output at 2160p with HDR. I think atmos is supported but don't have atmos set up presently. Also there is a specific application for KODI tuned to the shield called SPMC which is downloaded from the play store. Took less than 10 mins from powering on to having KODI set up with the same skin and file settings.
bigboss said:i3 processor, 16TB (8GB X 2 SATA hard drives) + 2TB SSD for OS, 8GB RAM and blu ray drive for £1135. This comes with a fan ("near silent"). OS is Linux. All software (including ripping) is preloaded.
What do you think of the price?
bigboss said:They have confirmed that it is indeed a 2TB SSD!
I believe it's makemkv.Feral said:bigboss said:i3 processor, 16TB (8GB X 2 SATA hard drives) + 2TB SSD for OS, 8GB RAM and blu ray drive for £1135. This comes with a fan ("near silent"). OS is Linux. All software (including ripping) is preloaded.
i'd want to know what ripping software is included and what formats are supported for bit rates, they are not all equal. Assuming you are going for a raided pair of 8tb drives you'll want to rip to mkv in h.265 to save space but you also need a player that can handle it. I'm using a simple 2 bay NAS with media server and no transcoding as this is all done by the shield. It takes significantly more time to encode in h.265 esp if you do not have software that can use CUDA acceleration on the gpu.
Isn't it better to load the OS on an SSD anyway? I don't think downgrade is possible. Basically, I'll only end up losing space if they use a smaller SSD, since I will want the OS on SSD.pauln said:bigboss said:They have confirmed that it is indeed a 2TB SSD!
Will they allow you to downgrade to something more reasonable? There is no need whatsoever for one so large, in fact the need for an SSD of any description in a media server is questionable unless it's to eliminate mechanical HDD's altogether to reduce noise - which you're not.
bigboss said:Isn't it better to load the OS on an SSD anyway? I don't think downgrade is possible. Basically, I'll only end up losing space if they use a smaller SSD, since I will want the OS on SSD.pauln said:bigboss said:They have confirmed that it is indeed a 2TB SSD!
bigboss said:I'm very sure I won't get a £500 discount by downgrading the SSD size, it'll be more like £100-150. If you look at the page, there isn't any option to choose the SSD size. The total price is very good though, isn't it? If you were offered the same specs with 128GB SSD instead, how much would it have cost?
bigboss said:I've been conversing with them on AV forums conversation.
I asked: Are you sure it's 2TB SSD?
They replied: Positive, we build them.
They further said: I will ask the guy who build them if we can steal some of the spare capacity of the 2TB and add it to the main 16TB storage. If i remember that is possible.
So I have a written confirmation from them. I can always return it if it doesn't match the specs they claim.
I say "they" but it's actually one person. I've dealt with him last year and bought few things from him during my home cinema build (speaker cables, Philips Hue lights etc.).
bigboss said:Thanks. So do you think i5 or even i7 will allow faster rips?
Isn't that more for gaming?pauln said:Also consider a platinum rated PSU which is more expensive initially but more efficient thus saving energy/cost long term/the environment and of course creating less waste heat in your cupboard under the stairs - both aspects quite important if your machine is going to be working it's ass off round the clock.
