That's interesting! So I can connect an external HDD to it for more storage, and even install Windows 7 with mymovies if I don't like Kodi.daveh75 said:Kodi can't or at least couldn't decode Atmos, but it will do passthrough. So all you need is a PC with HDMI out and let your AV receiver do the decoding.
There are some nice small form factor PCs about.
I backed the Wood Kubb back in the summer on Kickstarter for example, which will be a Kodi box on my main system + a TVHeadend server to feed a bunch of Raspberry Pis dotted around the house.
http://www.kubb.eu/en/16-the-shop/
Thanks, this looks quite similar to Innuos hardware wise. Looks beautiful!!Q5 said:Not sure if this gives any further inspiraration.
http://www.hifidelit.com/
Link from the above site
bigboss said:This seems to be a good value media server which can go up to 18TB. Will work straight on my Oppo but without the fancy movie wall.
http://store.aclasstechnology.com/media-server-2566-p.asp
I've read on AVS forum about a modded Oppo 103D which then displays a movie wall but didn't divulge further information. Anyone has any idea about it?
bigboss said:That's interesting! So I can connect an external HDD to it for more storage, and even install Windows 7 with mymovies if I don't like Kodi.
bigboss said:Cheers! That looks very good! I'm assuming I'll need a media player separately to go with it, considering it doesn't have an HDMI port?
bigboss said:Thanks Feral, sorry for the (very) late response, as I had put this in the back burner for a while. It's probably the right time to revisit this. I read somewhere about Kodi not supporting Atmos, so not sure.
That's interesting, thanks! I need to read more about it. With this option, all I'll need is a NAS drive and an android media player (or use Amazon Fire if that supports Atmos), right? I have an external blu ray drive, and I can use my laptop to rip my blu rays uncompressed to the NAS drive.daveh75 said:bigboss said:Thanks Feral, sorry for the (very) late response, as I had put this in the back burner for a while. It's probably the right time to revisit this. I read somewhere about Kodi not supporting Atmos, so not sure.
It does.
The Kodi team have now even got DTS-HD, DTS-X, Dolby TrueHD and Dolby ATMOS passthrough working on Android in the latest dev builds, ie v17 aka Krypton which is currently in its first beta atm.
bigboss said:That's interesting, thanks! I need to read more about it. With this option, all I'll need is a NAS drive and an android media player (or use Amazon Fire if that supports Atmos),daveh75 said:bigboss said:Thanks Feral, sorry for the (very) late response, as I had put this in the back burner for a while. It's probably the right time to revisit this. I read somewhere about Kodi not supporting Atmos, so not sure.
It does.
bigboss said:Thanks! Yes, I've been looking at NVidia Shield. Will I get all movie info on Kodi?
bigboss said:Thanks pauln! That's the only motherboard option they have.
When I asked quiet PC, this was their response:
"You have gone for the lowest processor on the list, it will play movies at 4K but you will not be able to run other programs in the background when doing this. Think of processors as multitasking or the amount of task you can do at one time, the more powerful the processor the more things you can do but as mentioned if you are only running one program at a time the processor will be fine."
Any thoughts on this?
Thanks. I'm unable to get info of movies I already have in my NAS. In Boxee box, it's displayed as a movie wall with posters, and when you click on a particular movie, it brings up movie information and names of actors etc. In Kodi, even when I choose to view thumbnails instead of list, it only shows empty boxes with names of files. Any suggestions?daveh75 said:bigboss said:Thanks! Yes, I've been looking at NVidia Shield. Will I get all movie info on Kodi?
Yep.
If you've got an AFTV you really should just install Kodi on it and give it a try.
Thanks. Will look at the sites suggested.pauln said:bigboss said:Thanks pauln! That's the only motherboard option they have.
They have a limited range - there are other places to shop, probably cheaper than quietpc too - Scan and ebuyer are a couple I've used in the past. There's also Kustompcs.co.uk who have a huge range of Streacom and other fanless cases.
I would go for maybe an i5 6500 (65W) or an i3 6300T (35W) rather than the Pentium (47W) Less heat is obviously better for a fanless build and the i3 gives you more performance for less heat output. As to motherboards, Gigabyte and Asus do dozens of boards for the Skylake processors. You could browse a website like Scan and find the one that suits your needs; do you want thunderbolt or USB type c connectivity for instance. The Z170 chipset is intended for gamers who want to run multiple graphics cards so if you don't need that you could get an H110 chipset board and save around £50 or more, which would counter the extra you would have to pay for a better CPU.
If you don't have space for an SSD along with the three 2.5" drives, you could go for an M2 sata drive.
Are you going to build it yourself, if not I think Kustompcs do a bespoke build service, they certainly used to. Puget systems would be another good place to look.
If "quiet" is what you are after, check out silentpcreview.com for lots of info. Helped me source components for my "silent" builds!
