boston accoustic xs or cambridge audio minx mini10 for rear speakers
Hi
im after a set of small rear speakers that are wall mountable to be used as rears in my bedroom home cinema setup. now as theyre being wallmounted right behind my bed dont want something too big
ive been looking at both the boston xs and cambridge minx mini10 speakers and am unsure of which ones to get. has anyone had any experience of either systems and if so which would you recommend or are there any others i should be looking at
the speakers are gonna be used along side tonnoy f4 & fc speakers, ae sub and will be powered by a denon 2807
thanks
Out of the two it would have to be the bostons for me, I used to have the min20 as rear speakers and although they went very loud for their size, the surround placement wasn't very good IMO. If your budget and room layout allows the KEF T101s would be even better.
magnificent issues altogether, you simply won a new reader.
What could you suggest in regards to your put up that you
simply made some days ago? Any sure?
My web blog - denim
