Your concern is mildly valid there, they are not quite as comfy, but it seems that the better sound of the LE is vastly related to the pads so I'm not sure there would be much point getting the LE only to change the pads. The only point doing this would be if you needed a bit more volume from a portable or just like having a limited edition .Paulq said:Part of the attraction with Beyers for me is actually the velour pads as I find them extremely comfortable. Not sure about the plastic pads at all - do the replacement velour ones fit the LE?
quadpatch said:Your concern is mildly valid there, they are not quite as comfy, but it seems that the better sound of the LE is vastly related to the pads so I'm not sure there would be much point getting the LE only to change the pads. The only point doing this would be if you needed a bit more volume from a portable or just like having a limited edition .
dalethorn said:NwAvGuy says the 80 ohm are very marginal with ipod etc.
Edit: The FiiO should help.
Paulq said:Is there a better, reasonably priced, portable headphone amp you'd recommend to do the 80 ohm's justice with iPod etc?
Which one has bass there? The DT770 LE?dalethorn said:I don't know what the older DT770's are like, but the LE I got has a light clamp, and the fit is the most comfortable thing I've used except maybe the Shure 1840, and it's close to that. It's three times more comfortable than the Sennheiser Momentum. I can see a concern for warm weather, but unless a person's head gets unusually hot it shouldn't be much problem. BTW, I was listening to the ATH ESW11 all day, and switching to the DT770, it has bass! - Amazing difference.
quadpatch said:Paul: I now have the DT880 / 600 Ohm and the DT770 / 32 Ohm and I still really want to get the DT990! I'd love to know what you think of the DT770, whichever version you end up getting.
quadpatch said:Which one has bass there? The DT770 LE?
It's interesting what you say about the clamp. I found the clamp of the DT770 LE to be somewhere between average and slightly annoying, but not as bad as I remember the original DT770, which was deffinitely annoying. It's weird because the DT880 clamp I have is definitely light. I wonder if there is random variations because they all look they're made from the same parts.
