jcbrum said:
Bozak Symphonys are an early sixties design, which have no acoustic suspension. Most other manufacturers introduced acoustic suspension for the driver cone from the late fifties onwards, and it became an almost universal feature.
Don't you think, lindsayt, that loudspeaker drive unit design has made any progress towards better fidelity in the last fifty years ?
JC
JC here's a quote from the Wikipedia entry for Acoustic Suspension speakers:
The acoustic-suspension woofer (sometimes known as “air suspension”) uses the elastic cushion of air within a sealed enclosure to provide the restoring force for the woofer diaphragm.
Unlike the stiff suspension of conventional speakers, the trapped air inside the sealed-loudspeaker enclosure provides a more linear restoring force for the woofer's
diaphragm, enabling it to oscillate a greater distance (excursion) in a linear fashion. This is a requirement for clean reproduction of deep-bass tones by drivers with relatively small cones (e.g. smaller than 12-16 inches in diameter) not mounted in a horn or similar for increased coupling at low frequencies enclosure. Acoustic suspension cabinets are not entirely airtight. A small amount of airflow must be allowed so the speaker can adjust to changes in atmospheric pressure."
The Bozak Symphonys use two 12" bass drivers per cabinet. So, according to the wiki entry, acoustic suspension does not apply to them. With that cone size they move much less (6.7 times less) than a single 6.5" cone.
Also, the problemn with acoustic suspension is transient response. The air acts as a spring reducing transient response. Put the speaker cones in a large enough cabinet and the spring effect from the air is minimal.
Now JCBrum, can you please explain to me how bass distortion and bass transient response has improved in the last 50 years when you compare AVI ADM 40's against Bozak Symphonys, from a theoretical point of view?
And of course, the proof of the pudding is in the eating. Or in the case of hi-fi in the listening - which you apparently don't want to do?
