Best speaker cable around skirting boards solution
Question just as the title says really.
Want single cable to accomodate both rear speakers of a surround sound system that can fit along the top of my flat white skirting boards. Any advice on where to buy, how to fit and how to connect appreciated.
This is probably the best option, if it's narrow enough to fit on top of the skirting boards. You could pin through the central divide between the two conductors using very small panel pins, but you will have to stack two runs to feed both speakers. But then it's only 1mm thick.
Any QED retailer will sell it, and you can either terminate it with banana plugs at each end, or just connect it to your receiver and speakers using bare wire ends.
