My needle on my Project Debut 2 is knackered (I'm pretty sure)
I'm looking for a cheap replacement in the meantime, the 5e (which is what it is currently) are about £45 which seems a little steep considering I only paid £80 for the table.
What would you guys recommend?
Also, I'm thinking of replacing the tonearm but is there any point doing so on such an entry level table or is the tonearm the only thing makes a difference? (I'm a noob at this stuff)
Cheers!
Cheers!
