Best Budget Mains Cables?
As I'm about to embark on buying a new AV system - I'm currently investigating all the options.
I'm intending to use an old Russ Andrews 8 way power distribution block with mains filtering and spike protection - but are his budget mains cables (from the equipment to the block) the best value / offer the best improvements?
Regards,
Mark.
kusum65
68
Im sure they are good quality,everyone raved about the Yellow
cable when it was around and that cost £30. I recently had the same
dillema and found the Merlin site were discounting their cables. Last
week i went to one of there distributors,Hi-Fi care in london and
bought a tarantula for my mains block for £40 and a black widow for my
cd player at £65 down from £80. Bearing in mind i hadnt used the block
until that point i was very impressed with the result.It took a couple
of days but i have better tonal balance and a bit more punch.
davidvann
21
hi madmark,i agree with cno,check out clearer audio,just bought a cable from clearer audio am over the moon with it,darren is very helpful and will guide you on which cable to get the best from your system.cheers david
TrevC
526
246
19,270
:rofl: My stuff all came with mains leads. All with excellent "tonal balance" too. Whatever that is.
Can the 50Hz mains have tonal balance? :rofl: :rofl:
