drummerman said:
Why do people not mention budget??
My suggestion would be a BelCanto C75i or Cyrus 8 series amplifier and a pair of MAD 1920's
Hmm my bad, I should have mentioned the budget, of course. I am putting the pain limit around 400€, with an absolute hard limit at 500€. I would, of course, like to get away with paying as little as possible, without compromising the audio quality all too much. Hence the question of finding a balance between good audio quality, practicality and price.
As for the suggestions go, I like the Bel Canto C5i, based on the features and the looks, but the cheapest deal here in Sweden appears to be beyond 2000€ which is over my budget by a mile. Thanks anyways!
TazLondon said:
I've just bought a Marant PM6005 amp and Q Acoustics 2020i speakers for my bedroom. I've connected an Apple TV via an optical cable to the amp's Toslink input. The sound is far, far better than anything I could have hope for with active speakers. Around the home I also have a couple of Audyssey active speakers with Airplay. The sound from them is quite good but the amp + speakers combo is in another league altogether.
Some of the considerations I had for an amp in the bedroom were: must have bass/treble/loudness controls as I tend to listen at very low volumes, power output is fairly irrelevant for a bedroom (I haven't even turned the amp up beyond 10% of the volume control yet!), multiple input to connect other audio sources (e.g. Sky HD box, Blu-Ray player) - you often don't get that level of flexibility with active speakers. I also specifically wanted an amp with an outstanding DAC to get the best sound possible from my Apple lossless music streamed from my Mac to my Apple TV. The Apple TV only has an optical out for audio so I made sure the amp has an optical in jack.
Hope some of that helps as I've just done what you're thinking of doing!
Thanks for the detailed answer. Based on your explanation of pros/cons, I'd say I have the same understanding. Although the tricky bit is to find the right compromise... I read a bit about the amp and the speakers you suggested. I really like the QA 2020i, both aesthetically and audio quality based on the reviews available. Unfortunately I can't say the same about the amp, as it's not what I am after, neither economically (at least here in Sweden) nor aesthetically (too large and clumpy).
To give an idea about what I am looking at, here are some of the stuff I have been interested at so far. Any and all comments are welcome:
- Active speakers:
Edifier R2600 Studio 6. These are priced quite nicely, and seem to have gotten few but very positive reviews. I understand that they are primarily desktop speakers, but of somewhat higher quality. Anyone here has any experience with these?
- Compact amp:
Yamaha CRX-550. I like the fact that it's compact and not so "techy", fits nicely in a bedroom I'd say. I like that it has good connectivity, and a CD player to put a cherry on top. What Hi-Fi has
a quite positive review of this amp as well. I can get this little nice box for about 215€ here.
- All-in-one system: As I was browsing Yamaha's homepage for CRX550, I came across these new products they have announced: Relit and Restio series. They are nicely designed products that create not only the good audio, but also the right atmosphere. At least so claims Yamaha... I am particularly interested in the ISX-
803/
803D, and
LSX-170. I understand that these products won't be in the same league as a pair of good shelf/mount-speakers and an amp, but design-wise they are definitely attractive for my use-case.
One of the important questions is, if I want to connect the Airport Extreme to the sound system so I can stream from any devide in to the bedroom, the connection would practically be via 3,5mm audio jack. On
Apple's homepage they claim it's possible to get optical digital sound, which I don't quite understand. How can you get "optical digital sound" via an analog output?
