Bannana plugs FOR MA fx REARS???
Hi Piobob
What type of walls
soild or stud.
if they are the same as the RSFX than no, not unless you recess them in the wall using the template provided, you could then use a eyelet with a screwed thread in the recess with the cable passing through the eye part, then connect the bannana plugs ( then if you remove the speaker and the speaker cable drops it will not drop to the bottom of the stud wall.
smmee:
Hi Piobob
What type of walls
soild or stud.
if they are the same as the RSFX than no, not unless you recess them in the wall using the template provided, you could then use a eyelet with a screwed thread in the recess with the cable passing through the eye part, then connect the banana plugs ( then if you remove the speaker and the speaker cable drops it will not drop to the bottom of the stud wall.
Hi Smmee
Thanks for reply and good advice
, My walls are brick , so I guess It'll be simple wire connections. Don't want to start knocking the walls around again, just decorated
you could just use a drill with a bit of tape wrapped around ( to use as a depth gauge) and then stitch drill the hole out. or you could just use them without the plugs.
smmee:you could just use a drill with a bit of tape wrapped around ( to use as a depth gauge) and then stitch drill the hole out. or you could just use them without the plugs.
JUST GONNA WIRE THEM TO THE POST'S DIRECT.............thanks anyway
