A admin_exported New member Aug 10, 2019 2,556 5 0 May 20, 2010 #1 Please help. How do I connect banana plugs to my NAD C355BEE amp? They don't seem to slot in anywhere although the manual suggests that 'pins' go down the centre of the binding posts. Thanks
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 May 20, 2010 #2 You need to remove the little plastic plugs in the middle of the binding posts.
Dave_ Well-known member Jul 31, 2008 1,593 890 20,570 May 20, 2010 #3 Due to EU regs, binding posts are fitted with 'bungs'. You need to remove the bungs with a small flat blade screwdriver or needle nose pliers.
D d_a_n1979 New member Sep 6, 2007 134 0 0 May 20, 2010 #4 Yup; just use the tip of a blade or even your finger nails (be careful though as the cap top is a little sharp) Pop them out and slide the banana plugs in
