hoopsontoast
- Oct 1, 2011
- 12
- 0
- 0
Craig M. said:hoopsontoast said:He is entitled to his wrong opinion 😉
🙂 Why, thankyou.
I am actually puzzled by your reaction to the ADMs though, I know from reading posts you've made that you appreciate SCM19s, I've compared them with the ADMs back to back in my livingroom and the over-riding impression both I and my cousin had was how similar the sound was. I'd have thought the ADMs would be right up your street.
Anyways, I apologise for my earlier post. It was a childish reaction.
Yes, I do indeed like the ATC SCM7, SCM10 and SCM19. They are however flawed but I feel have some qualaties that set them apart from other speakers with the expense of other atributes.
Now, I like those speakers not because they are passive, that they have a particular type of mid bass driver or even a particular design. The reason is they all seem to do the least wrong at their price point.
The SCM7/SCM10 in particular are dynamically limited, and lack much bass below 50Hz, dont sound their best at very low volumes but they do have a very transparent mid-range, very good integration between the mid-bass and tweeter and have very tight bass that helps with room integration.
The SCM19's are much the same but with added bass extension and dynamic ability at the expense of the mid-bass/tweeter integration and soundstage definition.
The same with my current speakers, the Magnepans. They dont have much output at all below 50Hz, they are difficult to place in a room, the vertical dispersion is terrible and they sound rubbish off-axis But they do do a lot that most other speakers dont. (Soundstage width, height and depth, midrange expression like vocals and super tight bass)
They do have one design feature that is a selling point, that is the dipole raditation, which like others (Quad ESL's and Apogees as well as true dipole cone speakers) has its own unique advantages and disadvantages that cant be matched by other types of speakers, active or passive.
I heard the original ADM9 (or 9.1 I cant remember) at the first Scalford hall, and much like yourself, I just found them underwhelming. They did not sound bad, but IMO they did not sound any different to most run of the mill 2-way 6" mid bass ported speakers. They did nothing that stood out to me that they excelled in.
Its all a compromise.
