Audioquest Red River, very (very) tight
ashleycox
Just purchased some audioquest red river XLR cables to connect up a Cambridge 851C/E/W system. I've noticed that the XLR connectors are non-standard; rather than having the clip on the side, they simply have a small round protrusion that lines up with the slot in the socket to insure they're oriented correctly.
The problem I have is that these are incredibly tight to insert and remove... like, they don't snap in like XLR's usually do. I've also noticed the small release buttons on the back of my preamp don't pop out when the cables are inserted, suggesting that these cables don't use the standard latching mechanism.
Does Anyone own these and can confirm whether this is by design, due to the non-standard plugs, the connectors on my ca gear, or just generally rubbish cables? They don't sound bad at all... it's just the possible damage caused by the tight connections worries me.
Frank Harvey
567
We have a few Audioquest XLR cables on demo, and we do find that they are tight in some equipment, but not all - they fitted fine on the Chord pre and powers, but very tight on the Musical Fidelity M6 range.
ashleycox
Thanks David. Would you advise I get some looser cables (if so, what), or is the tightness not going to damage anything?
alchemist 1
107
15
18,595
How do the Red river xlr's compare to Chord Chameleon cables ? Sound wise.
Frank Harvey
567
Try them :)
With the attitude of many on this forum with regards to cables, I don't really want to get into any discussions on the subject. Drop me an email and I'll sort out something for you to loan :)
alchemist 1
107
15
18,595
Try them :)
Muchas gracias, David. Yes it's a little early on Sunday morning for World War three.
