Jelco arms - depending on the model - are most likely to require a 210mm or 214mm or 222mm pivot to spindle distance, and (in the correct mount) have effective lengths of either 229m or 228mm or 237mm respectively.
Don't do it. (a) The geometry is all wrong (b) Yes, Jelco arms deserve much better turntables as suitable platforms.
Obviously there would be other considerations like whether that particular Jelco arm has a suitable range of arm-height adjustment to provide correct VTA on the Project, and if the thing will actually fit under the Project's lid, and if the counterweight (or it's stub) will foul against the lid through it's arc.
Anyway that's all moot.
